Travis Brundage created an issue |
Issue Type: |
Affects Versions: |
2.6.2 |
Assignee: |
Attachments: |
file_leak.xml, fnmoc-wps-file-desc-leak-0.48.0.jar, test_image.tif.gz |
Components: |
WCS |
Created: |
27/Feb/15 7:00 PM |
Priority: |
Reporter: |
There is a file descriptor leak which occurs in a failed WCS parameter call through WPS. This is confirmed to affect versions 2.6.2 and below. Steps to reproduce:
You should see the test_image.tif file still open after the command’s failure. This leads to many leaked processes over time. Note that you may need to adjust the permissions of these files in order to upload/use them correctly. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
