[Geoserver-devel] [jira] (GEOS-6925) 2.6.2 WMS rendering issue
Laurent Prevosto created an issue
GeoServer / BugGEOS-6925
Issue Type:
BugBug
Affects Versions:
2.6.2
Assignee:
Andrea Aime
wfs.xml
Components:
Oracle
Created:
03/Mar/15 11:50 AM
Environment:
Linux + Oracle Spatial
Priority:
CriticalCritical
Reporter:
Laurent Prevosto
When trying to upgrade from 2.3.2 to 2.6.2 we noticed the following regression.
Some polylines features become unviewable as the WMS request fail with the following error :
<ServiceExceptionReport xmlns=“http://www.opengis.net/ogc” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” version=“1.3.0” xsi:schemaLocation=“http://www.opengis.net/ogc http://myserver:8081/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd”>
<ServiceException code=“internalError”>
Rendering process failed Circular strings are restricted to 2 dimensions at the moment. Contributions to get ND support welcomed! Details: org.geoserver.platform.ServiceException: Rendering process failed at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:520) at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:258) at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:130) at org.geoserver.wms.GetMap.executeInternal(GetMap.java:510) at org.geoserver.wms.GetMap.run(GetMap.java:254) at org.geoserver.wms.GetMap.run(GetMap.java:125) at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:354) at sun.reflect.GeneratedMethodAccessor195.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319) at
We are using Geoserver on Linux and the data lies in an Oracle10g database with Oracle Spatial Geometry.
This was working fine with 2.3.2
I am joining a WFS equivalent of one the failing bounding box. Hopes this helps.
Regards.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
