[Geoserver-devel] [jira] (GEOS-6934) gwc fails to render 900913 gridset with ImageMosaic store and the contour style
Maciej Filocha created an issue
GeoServer / BugGEOS-6934
Issue Type:
BugBug
Affects Versions:
2.7-RC1, 2.6.2
Assignee:
Andrea Aime
gwc_files.tgz
Components:
GWC
Created:
12/Mar/15 3:15 AM
Environment:
Ubuntu 14
Apache Tomcat/7.0.52,
Java™ SE Runtime Environment (build 1.7.0_76-b13)
Priority:
MajorMajor
Reporter:
Maciej Filocha
I’ve set up a layer based on an ImageMosaic store - bunch of GeoTiffs in
EPSG:3857 projection with time and custom dimension (indexed by a
PostGIS datastore). Two different styles are used - first is a simple
RasterSymbolizer with a ColorMap. Second one is based on Transformation with ras:Contour.
Everything works well with standard WMS requests. However, when I switch to GeoWebCache to render EPSG:900913 tiles, the second style (with contours) throws an error:
“org.opengis.geometry.MismatchedReferenceSystemException: The coordinate reference system must be the same for all objects”
The gridset EPSG:4326 is handled by GWC with no errors at all.
Reproducible: Always
Example files included.
Detailed error log:
2015-03-11 09:19:40,596 INFO [org.geoserver.wms] -
Request: getServiceInfo
2015-03-11 09:19:40,596 DEBUG [org.geotools.util] -
InterpolationConverterFactory can be applied from Strings to
Interpolation only.
2015-03-11 09:19:40,596 DEBUG [org.geotools.util] - CRSConverterFactory
can be applied from Strings to CRS only.
2015-03-11 09:19:40,597 DEBUG [org.geotools.util] -
Interpolation only.
2015-03-11 09:19:40,597 DEBUG [org.geotools.util] - CRSConverterFactory
2015-03-11 09:19:40,601 DEBUG [org.geotools.util] -
Interpolation only.
2015-03-11 09:19:40,601 DEBUG [org.geotools.util] - CRSConverterFactory
2015-03-11 09:19:40,610 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2015-03-11 09:19:40,611 DEBUG [org.geotools.jdbc] - SELECT max(“time”)
FROM “public”.“PRESSURE_AT_MEAN_SEA_LEVEL_3857”
2015-03-11 09:19:40,612 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2015-03-11 09:19:40,614 DEBUG [org.geotools.rendering] - Computed scale
denominator: 3.49426414969308E7
2015-03-11 09:19:40,615 DEBUG [org.geotools.rendering] - Processing 1
stylers for http://www.opengis.net/gml:GridCoverage
2015-03-11 09:19:40,615 DEBUG [org.geotools.rendering] - creating rules
for scale denominator - 34,942,641.497
2015-03-11 09:19:40,615 DEBUG [org.geotools.util] -
Interpolation only.
2015-03-11 09:19:40,615 DEBUG [org.geotools.util] - CRSConverterFactory
Interpolation only.
Interpolation only.
2015-03-11 09:19:40,616 DEBUG [org.geotools.util] -
Interpolation only.
2015-03-11 09:19:40,616 DEBUG [org.geotools.util] - CRSConverterFactory
Interpolation only.
Interpolation only.
Interpolation only.
Interpolation only.
Interpolation only.
2015-03-11 09:19:40,616 DEBUG [org.geotools.rendering] - Expanding
rendering area by 6 pixels to consider stroke width
2015-03-11 09:19:40,617 DEBUG [org.geotools.rendering] - added attribute
grid
params
2015-03-11 09:19:40,618 DEBUG [org.geotools.rendering] - Querying layer
http://www.opengis.net/gml:GridCoverage with bbox:
ReferencedEnvelope[-58703.63771484376 : 5068080.722714845,
9960050.532285154 : 1.2582146350214843E7]
2015-03-11 09:19:40,618 TRACE [org.geotools.factory] - ENTRY
(GeometryFactory, JTS_GEOMETRY_FACTORY)
2015-03-11 09:19:40,618 TRACE [org.geotools.factory] - RETURN
(GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation
GeometryFactory.
GeometryFactory.
2015-03-11 09:19:40,620 DEBUG [org.geotools.gce.imagemosaic] - Reading
mosaic from
file:/var/lib/geoserver/data_dir/um_data/PRESSURE_AT_MEAN_SEA_LEVEL_3857/datastore.properties
2015-03-11 09:19:40,620 DEBUG [org.geotools.gce.imagemosaic] - Highest
res 6917.817807654886 6917.817807654886
2015-03-11 09:19:40,621 ERROR [org.geotools.rendering] - The coordinate
reference system must be the same for all objects.
at
org.geotools.geometry.jts.ReferencedEnvelope.ensureCompatibleReferenceSystem(ReferencedEnvelope.java:309)
at
org.geotools.geometry.jts.ReferencedEnvelope.intersects(ReferencedEnvelope.java:512)
at
org.geotools.gce.imagemosaic.SpatialRequestHelper.computeCropBBOX(SpatialRequestHelper.java:565)
at
org.geotools.gce.imagemosaic.SpatialRequestHelper.compute(SpatialRequestHelper.java:243)
at
org.geotools.gce.imagemosaic.RasterLayerRequest.<init>(RasterLayerRequest.java:213)
at
org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1132)
at
org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:863)
at
org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:842)
at
org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:147)
at
org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:227)
at
org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:217)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readSingleCoverage(GridCoverageReaderHelper.java:419)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverage(GridCoverageReaderHelper.java:165)
at
org.geotools.renderer.lite.StreamingRenderer$1.readCoverage(StreamingRenderer.java:2005)
at
org.geotools.renderer.lite.RenderingTransformationHelper.applyRenderingTransformation(RenderingTransformationHelper.java:141)
at
org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2013)
at
org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:820)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:494)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:258)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:130)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:510)
at org.geoserver.wms.GetMap.run(GetMap.java:254)
at org.geoserver.wms.GetMap.run(GetMap.java:125)
at
org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:354)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at
org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:80)
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at
at
org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at
at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy65.getMap(Unknown Source)
at
at
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:792)
at
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:274)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1174)
at
org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:573)
at
org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:518)
at
org.geoserver.gwc.layer.GeoServerTileLayer.getTile(GeoServerTileLayer.java:467)
at
org.geowebcache.GeoWebCacheDispatcher.handleServiceRequest(GeoWebCacheDispatcher.java:363)
at
org.geowebcache.GeoWebCacheDispatcher.handleRequestInternal(GeoWebCacheDispatcher.java:254)
at
at
org.geoserver.gwc.dispatch.GwcServiceProxy.dispatch(GwcServiceProxy.java:98)
at sun.reflect.GeneratedMethodAccessor139.invoke(Unknown Source)
at
at
at
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at
org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:439)
at
org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:178)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at
at
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at
at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at
at
at
org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at
at
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at
org.apache.tomcat.util.net.AprEndpoint$SocketWithOptionsProcessor.run(AprEndpoint.java:2378)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
2015-03-11 09:19:40,622 DEBUG [org.geotools.rendering] - Style cache hit
ratio: NaN , hits 0, requests 0
2015-03-11 09:19:40,623 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Rendering process failed
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:520)
at
at
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
