[Geoserver-devel] [jira] (GEOS-6955) Build failure in gs-wcs1_1 GeoCoverageTest raster filter tests for OpenJDK 7 only
Ben Caradoc-Davies created an issue
GeoServer / BugGEOS-6955
Issue Type:
BugBug
Affects Versions:
2.8-beta
Assignee:
Andrea Aime
Components:
WCS
Created:
25/Mar/15 6:36 PM
Environment:
debian/sid with:
Apache Maven 3.2.5 (12a6b3acb947671f09b81f49094c53f426d8cea1; 2014-12-15T06:29:23+13:00)
Maven home: /home/ben/java/maven
Java version: 1.7.0_75, vendor: Oracle Corporation
Java home: /usr/lib/jvm/java-7-openjdk-amd64/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: “linux”, version: “3.16.0-4-amd64”, arch: “amd64”, family: “unix”
Priority:
CriticalCritical
Reporter:
Ben Caradoc-Davies
Build fails in gs-wcs1_1 for OpenJDK 7:
Failed tests:   testRasterFilterRed(org.geoserver.wcs.GetCoverageTest): expected:<255> but was:<0>
  testRasterFilterGreen(org.geoserver.wcs.GetCoverageTest): expected:<255> but was:<0>
Failure can also be seen on Travis (picking a recent pull request), which fails at this point for openjdk7:
https://s3.amazonaws.com/archive.travis-ci.org/jobs/55769018/log.txt
but passes for oraclejdk:
https://s3.amazonaws.com/archive.travis-ci.org/jobs/55769017/log.txt
Attached images (RenderedImage dumped with ImageIO.write) show a line of black pixels down the left-hand side of each response.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
