Daniele Romagnoli created an issue |
Setup migration tool for NetCDF Mosaics created before GS 2.6.1 |
Issue Type: |
Assignee: |
Created: |
26/Mar/15 6:34 AM |
Priority: |
Reporter: |
https://jira.codehaus.org/browse/GEOT-4944 added a fix to setup proper imageLayout within the sampleImage created by the Imagemosaic for NetCDF/GRIB granules. This may result in issues when upgrading to GS > 2.6.0 (2.6.x x>=1, 2.7.x) in terms of harvesting. If this problem occurs, the quickest solution is:
*: if you have a set of netCDFs where each of them contains both temperature and humidity and they only differ for time values, you just need one file within your mosaic. If you have a set of NetCDFs where temperature and humidity are stored into different files, then you need at least 2 files (1 for temperature and 1 for humidity). Scope of this JIRA is to provide a scritp, a tool or an automatic way to do that |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
