Jody Garnett [Administrator] created an issue |
Issue Type: |
Affects Versions: |
2.8-beta |
Assignee: |
Components: |
Main |
Created: |
06/May/15 10:14 PM |
Priority: |
Reporter: |
GeoTools upstream is fixing GEOT-22 by migrating to EJML. This change affects the accuracy of some of our matrix calculations and has caused some regressions: It is not clear at this time if the following failures are due to an improvement or regression in calculation accuracy. GetFeatureInfoTestThe reference image before and after the change appears to be different (see attached screen snaps) resulting in a test failure when querying the requested point.
This message was sent by Atlassian JIRA (v6.5-OD-03-002#65000-sha1:b8f65f8) |
