[Geoserver-devel] [JIRA] (GEOS-7012) importer does not properly populate layerInfo for GeoJSON imports
Syrus Mesdaghi created an issue
GeoServer / BugGEOS-7012
Issue Type:
BugBug
Affects Versions:
2.6.4, 2.7.0
Assignee:
Unassigned
Components:
Importer
Created:
07/May/15 6:21 PM
Priority:
MediumMedium
Reporter:
Syrus Mesdaghi
When importing a GeoJSON file, the LayerInfo object returned by the task is not sufficiently populated. Even thought the importer can successfully import GeoJSON files, applications (such as GeoNode) that rely on the rest endpoint to retrieve additional data about the imported layer, get an exception.
http://localhost:8080/geoserver/rest/imports/1/tasks/0?expand=3
java.io.IOException: Schema ‘<layer name>’ does not exist.
at org.geotools.data.store.ContentDataStore.ensureEntry(ContentDataStore.java:619)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:386)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:353)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:337)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:711)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:103)
at org.geoserver.catalog.ResourcePool.getNonCacheableFeatureType(ResourcePool.java:939)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:863)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:858)
at org.geoserver.catalog.ResourcePool.loadAttributes(ResourcePool.java:735)
at org.geoserver.catalog.ResourcePool.getAttributes(ResourcePool.java:711)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.attributes(FeatureTypeInfoImpl.java:105)
at org.geoserver.importer.rest.ImportJSONWriter.featureType(ImportJSONWriter.java:295)
at org.geoserver.importer.rest.ImportJSONWriter.layer(ImportJSONWriter.java:278)
at org.geoserver.importer.rest.ImportJSONWriter.task(ImportJSONWriter.java:198)
at org.geoserver.importer.rest.TaskResource$ImportTaskJSONFormat.write(TaskResource.java:345)
Will try to have a pull request soon.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-03-002#65000-sha1:b8f65f8)
Atlassian logo
