[Geoserver-devel] [JIRA] (GEOS-7021) Rendering process failed java.io.IOException No more data to read from socket
Martin Wegner created an issue
GeoServer / BugGEOS-7021
Issue Type:
BugBug
Affects Versions:
2.7.0
Assignee:
Unassigned
Created:
13/May/15 4:51 PM
Priority:
HighestHighest
Reporter:
Martin Wegner
I’m using OpenLayers 3.5 and the Geoserver Oracle Extension.
While zooming the following URL will be created which ends in an exception (Rendering process failed java.io.IOException No more data to read from socket):
> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=true&LAYERS=layername&STYLES=stylename&CQL_FILTER=REFERENCE_DATE DURING 2015-02-05T23:00:00/2015-02-05T23:59:59&CRS=EPSG:4326&WIDTH=2033&HEIGHT=1004&BBOX=-95.086669921875,-197.523193359375,81.397705078125,159.840087890625
The generated SQL from the Geoserver log:
> SELECT LONG_LAT as LONG_LAT FROM EAMDAR.EAMDAR_REPORTS_VIEW WHERE (REFERENCE_DATE BETWEEN TO_DATE(‘20150205230000’, ‘YYYYMMDDHH24MISS’) AND TO_DATE(‘20150205235959’, ‘YYYYMMDDHH24MISS’) AND (SDO_FILTER(LONG_LAT, MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-179.99,-89.99,160.543212890625,82.100830078125)), ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’ OR SDO_FILTER(LONG_LAT, MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-95.789794921875,161.773681640625,82.100830078125,180.0)), ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’ ))
Maybe the problem is the -197 longitude?
The stacktrace is:
> 2015-05-13 14:10:20,336 ERROR [geotools.rendering] - java.io.IOException
> java.lang.RuntimeException: java.io.IOException
> at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:167)
> at org.geoserver.feature.RetypingFeatureCollection.features(RetypingFeatureCollection.java:46)
> at org.geoserver.feature.RetypingFeatureCollection.features(RetypingFeatureCollection.java:32)
> at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2384)
> at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2109)
> at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:829)
> at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:494)
> at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:258)
> at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:130)
> at org.geoserver.wms.GetMap.executeInternal(GetMap.java:504)
> at org.geoserver.wms.GetMap.run(GetMap.java:248)
> at org.geoserver.wms.GetMap.run(GetMap.java:119)
> at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:354)
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:497)
> at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
> at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
> at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
> at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
> at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
> at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
> at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
> at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
> at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
> at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
> at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
> at com.sun.proxy.$Proxy21.getMap(Unknown Source)
> at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:839)
> at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:280)
> at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
> at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
> at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
> at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
> at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
> at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
> at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
> at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
> at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
> at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
> at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
> at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
> at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
> at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
> at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
> at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
> at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
> at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
> at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
> at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
> at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
> at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
> at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
> at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
> at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
> at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
> at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
> at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
> at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
> at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
> at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
> at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
> at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
> at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
> at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
> at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
> at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
> at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
> at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518)
> at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091)
> at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:668)
> at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:223)
> at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1517)
> at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1474)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
> at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
> at java.lang.Thread.run(Thread.java:745)
> Caused by: java.io.IOException
> at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:642)
> at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:612)
> at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:164)
> … 126 more
> Caused by: java.sql.SQLRecoverableException: No more data to read from socket
> at oracle.jdbc.driver.T4CMAREngine.unmarshalUB1(T4CMAREngine.java:1157)
> at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:290)
> at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
> at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
> at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:207)
> at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:884)
> at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1167)
> at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1289)
> at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3584)
> at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3628)
> at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1493)
> at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
> at org.geotools.jdbc.JDBCFeatureReader.<init>(JDBCFeatureReader.java:168)
> at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:606)
> … 128 more
> 2015-05-13 14:10:20,348 DEBUG [geoserver.wms] - Got an unexpected render exception.
> … 126 more
> … 128 more
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-03-002#65000-sha1:b8f65f8)
Atlassian logo
