[Geoserver-devel] [JIRA] (GEOS-7023) No FID expression found for type
Bruce Simons created an issue
GeoServer / BugGEOS-7023
Issue Type:
BugBug
Affects Versions:
1.2.5
Assignee:
Unassigned
geoserver.log-1.txt
Components:
Application schema
Created:
15/May/15 7:19 AM
Environment:
PostgreSQL 9.3
Geoserver 2.6.1
TomCat 8.0
Windows 7 Enterprise 64 bit
Priority:
MediumMedium
Reporter:
Bruce Simons
When using Geoserver app-schema I am getting the following errors:
  1. Request: service=wfs&version=1.1.0&request=getFeature&typeName=
{requested feature type}&outputFormat=gml32&featureID={feature ID}
Error: “java.lang.IllegalStateException: No FID expression found for type [http://www.opengis.net/[requested](http://www.opengis.net/[requested) feature type]. Did you mean Expression.NIL?” when doing a request of type:
  1. Request: service=wfs&version=1.1.0&request=getFeature&typeName={requested feature type}
&outputFormat=gml32&maxFeatures=1
Results in no error message, but the feature gml:id is populated with the <sourceType> from the FEATURE_LINK, with no other properties returned.
Stopping and starting TomCat (without changing any Geoserver configuration files) will eventually result in a correctly populated response, although requests to other features that previously worked, may now fail and return the above errors. Once the feature request is not giving the FID error it seems to continue working until restarted.
When the configuration is one Feature with no feature links it doesn’t seem to fail (although the maxFeatures=5 is slow), but adding a single FEATURE_LINK can give (but not always) the FID error.
I’m not accessing app-schema feature types using “workspace-specific” service URLs.
Not sure if this is related, but layer preview for the service also fails (example from externally facing service):
http://gwservices.it.csiro.au:8080/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.demo.MapPreviewPage
Attached is the log from this query
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-03-002#65000-sha1:b8f65f8)
Atlassian logo
