Marcus Sen created an issue |
Issue Type: |
Affects Versions: |
2.7.1 |
Assignee: |
Unassigned |
Created: |
21/May/15 6:37 PM |
Labels: |
INSPIRE |
Priority: |
Reporter: |
Currently the INSPIRE plugin puts a schemaLocation which includes “http://inspire.ec.europa.eu/schemas/inspire_vs/1.0 http://localhost:8080/geoserver/www/inspire/inspire_vs.xsd” for the INSPIRE view service namespace. However, this local schema is a very minimal wrapper which imports two other schemas from the Internet:
So there doesn’t seem to be any benefit from hosting this small wrapper locally rather than using the canonical location at http://inspire.ec.europa.eu/schemas/inspire_vs/1.0/inspire_vs.xsd . There is a comment above the getSchemaLocations method in org.geoserver.inspire.wms.WMSExtendedCapabilitiesProvider asking whether the XSD still needs hosting. See also email thread at http://sourceforge.net/p/geoserver/mailman/message/34125799/ I will submit a pull request. (I couldn’t work out which component this should be filed under as INSPIRE extension wasn’t an option.) |
This message was sent by Atlassian JIRA (v6.5-OD-03-002#65000-sha1:b8f65f8) |
