[Geoserver-devel] [JIRA] (GEOS-7062) App-schema oracle tests fail on jenkins
Jody Garnett [Administrator] created an issue
GeoServer / BugGEOS-7062
Issue Type:
BugBug
Affects Versions:
2.8-beta
Assignee:
Ben Caradoc-Davies
Components:
Application schema
Created:
08/Jun/15 10:22 PM
Environment:
jenkins
Labels:
jenkins
Priority:
MediumMedium
Reporter:
Hi Ben: As you are aware the environment used by jenkins does not have quite the required environment required for App-Schema Oracle tests. This issue gives us a chance to track what is needed, and see if the test can be fixed another way.
Example failure:
Caused by: java.sql.SQLSyntaxErrorException: ORA-00904: "ARES"."SC4O"."ST_GEOMFROMEWKT": invalid identifier
	at org.geotools.jdbc.JDBCTestSetup.run(JDBCTestSetup.java:162)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-05-041#65001-sha1:e07c9f6)
Atlassian logo
