Tore Halset created an issue |
Issue Type: |
Affects Versions: |
2.7.1 |
Assignee: |
Unassigned |
Created: |
18/Jun/15 1:01 PM |
Priority: |
Reporter: |
In http://dalsnuten.ecc.no/~halset/tmp/imagemosaicnodata/ , there are four GeoTIFF-files made by converting BAG-files to GeoTIFF with gdal. gdalinfo report that all four GeoTIFFs have 1000000 as nodata value. In GeoServer, I add the directory as a ImageMosaic store. When publishing the layer, it does not seem like the nodata value is recogniced. In the “Edit Layer” under “Coverage Band Details”, the “Null Values” of the two bands are “-”. I expected 1000000. I then create a file with the following content and run gdalinfo on it. The gdalinfo show no sign of a NoData value. My next attempt was to edit the layer and change “Null Values” from “-” to 1000000. I then recreated (since gdalinfo change the content of the file) the above file and rerun gdalinfo. Still no sign of a NoData value. |
This message was sent by Atlassian JIRA (v6.5-OD-05-041#65001-sha1:e07c9f6) |
