[Geoserver-devel] [JIRA] (GEOS-7078) Coordinates are changed in the resulting sql when performing a bbox filter in WFS (url parameter)
Rune created an issue
GeoServer / BugGEOS-7078
Issue Type:
BugBug
Affects Versions:
2.7.1
Assignee:
Unassigned
Components:
WFS
Created:
18/Jun/15 3:51 PM
Environment:
Geoserver 2.7.1, sqlserver
Priority:
MediumMedium
Reporter:
Rune
(sorry if it has been reported before, but i was not able to find it)
I tried to make a request for a number of features within a bbox with the following url
http://[host]/geoserver/GEO/wfs?version=1.1.0&request=GetFeature&typename=[layer]&outputFormat=application/json&srsname=EPSG:4326&filter=<Filter xmlns=“http://www.opengis.net/ogc” xmlns:gml=“http://www.opengis.net/gml"&gt;&lt;BBOX&gt;&lt;PropertyName&gt;geom&lt;/PropertyName&gt;&lt;gml:Box%20srsName="EPSG:4326”><gml:coordinates>12.530799742947515,54.66337753988665 12.550165292031572,55.670753796871054</gml:coordinates></gml:Box></BBOX></Filter>
And got the following result:
{“type”:“FeatureCollection”,“totalFeatures”:1615,“features”:,“crs”:null}
Looking a the result, it was strange to find no feature even though it has counted 1615, so i looked in the geoserver log to find out why:
2015-06-18 15:26:25,848 INFO [geoserver.wfs] -
Request: getFeature
service = WFS
version = 1.1.0
baseUrl = http://localhost:8080/geoserver/
query[0]:
filter = [ geom bbox POLYGON ((12.530799742947515 54.66337753988665, 12.530799742947515 55.670753796871054, 12.550165292031572 55.670753796871054, 12.550165292031572 54.66337753988665, 12.530799742947515 54.66337753988665)) ]
srsName = EPSG:4326
typeName[0] =
{www.geo.dk/1.0.0}
[layer]
outputFormat = application/json
resultType = results
2015-06-18 15:26:25,848 INFO [wfs.json] - about to encode JSON
2015-06-18 15:26:25,848 DEBUG [geotools.jdbc] - CREATE CONNECTION
2015-06-18 15:26:25,926 DEBUG [geotools.jdbc] - CLOSE CONNECTION
2015-06-18 15:26:25,926 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2015-06-18 15:26:25,926 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2015-06-18 15:26:25,942 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2015-06-18 15:26:25,942 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2015-06-18 15:26:25,942 DEBUG [geotools.jdbc] - CREATE CONNECTION
2015-06-18 15:26:25,942 DEBUG [geotools.filter] - exporting PropertyName
2015-06-18 15:26:25,942 DEBUG [geotools.filter] - exporting LiteralExpression
2015-06-18 15:26:25,942 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-06-18 15:26:25,942 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-06-18 15:26:25,942 DEBUG [geotools.jdbc] - SELECT count FROM (select
from
where (…
) as “vtable” WHERE “geom”.Filter(geometry::STGeomFromText(‘POLYGON ((12.530799742947515 54.66337753988665, 12.530799742947515 55.670753796871054, 12.550165292031572 55.670753796871054, 12.550165292031572 54.66337753988665, 12.530799742947515 54.66337753988665))’, 4326)) = 1
2015-06-18 15:26:26,051 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-06-18 15:26:26,051 DEBUG [geotools.jdbc] - CLOSE CONNECTION
2015-06-18 15:26:26,051 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2015-06-18 15:26:26,051 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2015-06-18 15:26:26,051 DEBUG [geotools.jdbc] - CREATE CONNECTION
2015-06-18 15:26:26,051 DEBUG [geotools.filter] - exporting PropertyName
2015-06-18 15:26:26,051 DEBUG [geotools.filter] - exporting LiteralExpression
2015-06-18 15:26:26,051 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-06-18 15:26:26,051 DEBUG [geotools.jdbc] - SELECT top 1000000 “id”,“geom” as “geom”,“mapsymbol”,“projectType” FROM (select
from
where (…
) as “vtable” WHERE “geom”.Filter(geometry::STGeomFromText(‘POLYGON ((54.66337753988665 12.530799742947515, 54.66337753988665 12.550165292031572, 55.670753796871054 12.550165292031572, 55.670753796871054 12.530799742947515, 54.66337753988665 12.530799742947515))’, 4326)) = 1
2015-06-18 15:26:26,082 DEBUG [geotools.jdbc] - CLOSE CONNECTION
And i found the reason why. In the two sqls, the order of x and y coordinate are change, such that in the first sql it return the right result, but in the second the order y, x instead of x,y and it returns no result
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-05-041#65001-sha1:e07c9f6)
Atlassian logo
