[Geoserver-devel] [JIRA] (GEOS-7085) WCS/WFS does not add Proxy Base URL to metadata links
Steve Ikeoka created an issue
GeoServer / BugGEOS-7085
Issue Type:
BugBug
Affects Versions:
2.8-M0, 2.7.1
Assignee:
Unassigned
Components:
WCS, WFS
Created:
22/Jun/15 6:02 PM
Priority:
MediumMedium
Reporter:
Steve Ikeoka
When a layer has a metadata link set without a host, the WMS 1.1.1 and 1.3.0 GetCapabilities responses will transform the link using the proxy base URL.
For example, if the proxy base url is “http://localhost/geoserver” and the metadata link is “/rest/metadata?layer=test1” then in the WMS capabilities, it will be “http://localhost/geoserver/rest/metdata?layer=test1”.
This transformation is not being applied to metadata links in WCS 1.0.0 DescribeCoverage, WCS 1.0.0 GetCapabilities, WCS 1.1.1 DescribeCoverage, WCS 1.1.1 GetCapabilities, WFS 1.1.0 GetCapabilities and WFS 2.0.0 GetCapabilities requests.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-07-005#65007-sha1:7561251)
Atlassian logo
