Tom Saul created an issue |
Issue Type: |
Affects Versions: |
2.7.1.1 |
Assignee: |
Unassigned |
Components: |
REST |
Created: |
26/Jun/15 8:49 PM |
Environment: |
WAR under tomcat 8, Java 7 |
Priority: |
Reporter: |
When using /geoserver/gwc/rest/seed/, passing in a XML command via PUT, if the <type> value is not correct, the system accepts the command, returns a 200 result, and proceeds to perform a seed operation. For example, if the command is entered as ‘truncateX’ it proceeds to seed the layer. |
This message was sent by Atlassian JIRA (v6.5-OD-07-005#65007-sha1:7561251) |
