[Geoserver-devel] [JIRA] (GEOS-7106) WFS DescribeFeatureType NPE with misconfigured layers
Lorenzo Pini created an issue
GeoServer / BugGEOS-7106
Issue Type:
BugBug
Affects Versions:
2.6.4
Assignee:
Unassigned
Components:
WFS
Created:
14/Jul/15 1:29 PM
Environment:
Version 2.6.4
Git Revision e522cb760457751b496e42b1169f8a344f934849
Running on Tomcat 6
Java OpenJDK 64-Bit Server VM 1.7.0_79
Priority:
LowLow
Reporter:
Lorenzo Pini
An SQL View can be configured to have spaces in the Attributes names.
WFS DescribeFeatureType call fails with a java.lang.NullPointerException on such layers.
To reproduce, create an SQL View with aliases and spaces names:
SELECT prop1 AS "Prop with spaces", geom  from my_table;
Publish it and just do a DescribeFeatureType on it
http://192.168.1.69:80/geoserver/wfs?&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME
=it.geosolutions%3Atest_view
This is the response:
<ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ows="http://www.opengis.net/ows"
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www
.opengis.net/ows http://192.168.1.69:80/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
  <ows:Exception exceptionCode="NoApplicableCode">
    <ows:ExceptionText>java.lang.NullPointerException</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
And this is the GeoServer log:
2015-07-14 10:56:59,552 INFO [geoserver.filters] - 192.168.1.114 "GET /geoserver/wfs?&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=it.geosolutions%3Atest_view" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:39.0) Gecko/20100101 Firefox/39.0" "http://localhost:8081/?config=spatialSelectorQueryConfig"
2015-07-14 10:56:59,553 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/wfs]
2015-07-14 10:56:59,553 DEBUG [ows.OWSHandlerMapping] - Mapping [/wfs] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2015-07-14 10:56:59,554 INFO [geoserver.wfs] -
Request: getServiceInfo
2015-07-14 10:56:59,555 INFO [geoserver.wfs] -
Request: describeFeatureType
    service = WFS
    version = 1.1.0
    baseUrl = http://192.168.1.69:80/geoserver/
    typeName[0] = test_view
    outputFormat = text/xml; subtype=gml/3.1.1
2015-07-14 10:56:59,556 ERROR [geoserver.ows] -
        at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.buildSchemaInternal(FeatureTypeSchemaBuilder.java:192)
        at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.build(FeatureTypeSchemaBuilder.java:149)
        at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.build(FeatureTypeSchemaBuilder.java:143)
        at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.build(FeatureTypeSchemaBuilder.java:132)
        at org.geoserver.wfs.xml.v1_1_0.XmlSchemaEncoder.doWrite(XmlSchemaEncoder.java:107)
        at org.geoserver.wfs.xml.v1_1_0.XmlSchemaEncoder.write(XmlSchemaEncoder.java:96)
        at org.geoserver.wfs.WFSDescribeFeatureTypeOutputFormat.write(WFSDescribeFeatureTypeOutputFormat.java:80)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:937)
        at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:278)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:723)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
        at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
        at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
        at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
        at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
        at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
        at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
        at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
        at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
        at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
        at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
        at org.geoserver.security.GeoServerAuthenticationKeyFilter.doFilter(GeoServerAuthenticationKeyFilter.java:105)
        at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
        at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
        at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
        at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
        at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
        at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:82)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
        at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
        at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
        at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
        at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:311)
        at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
        at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
        at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
        at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
        at java.lang.Thread.run(Thread.java:745)
2015-07-14 10:56:59,559 DEBUG [geoserver.filters] - Compressing output for mimetype: application/xml
2015-07-14 10:56:59,560 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2015-07-14 10:56:59,560 INFO [geoserver.filters] - 192.168.1.114 "GET /geoserver/wfs?&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=it.geosolutions%3Atest_view" took 8ms
I know that attributes names should be no-colon-name, can WFS just ignore (and don’t output) the invalid ones?
Regards
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-08-001#65007-sha1:1fc9846)
Atlassian logo
