[Geoserver-devel] [JIRA] (GEOS-7127) ImageMosaic custom CRS GeoTIFF strange handling
Maciej Filocha created an issue
GeoServer / BugGEOS-7127
Issue Type:
BugBug
Affects Versions:
2.7.1
Assignee:
Unassigned
indexer.xml, wrf_d02_T2_201504040600_001crs.tiff
Components:
WMS
Created:
27/Jul/15 4:43 PM
Environment:
Ubuntu 14.04.2, tomcat7 + Java™ SE Runtime Environment (build 1.8.0_45-b14)
Labels:
ImageMosaic
Priority:
HighHigh
Reporter:
Maciej Filocha
I see some inconsistency (a bug?) in a way Geoserver handles GeoTIFF
files with custom coordinate reference system.
In case you import attached file directly as a GeoTIFF:
  • it is correctly displayed in the Google Earth (as a kml file)
  • Layer Preview in Geoserver shows empty image
If you import it as ImageMosaic layer (indexer.xml file attached):
  • it is displayed upside down, both in the Layer Preview and the Google Earth
Differences starts from coverage.xml files: “scaleY” parameters have
opposite sign, “translateY” value is different. I noticed also that
org.geotools.gce.imagemosaic applies additional (unnecessary?) affine transform before
displaying the image.
GeoTIFFs with other custom CRS have similar problems, so I think it’s
more general issue.
CRS definition:
100102=PROJCS[“WRF Lambert”,GEOGCS[“WGS 84”,DATUM[“World Geodetic System
1984”,SPHEROID[“WGS
84”,6378137.0,298.257223563,AUTHORITY[“EPSG”,“7030”]],AUTHORITY[“EPSG”,“6326”]],PRIMEM[“Greenwich”,0.0,AUTHORITY[“EPSG”,“8901”]],UNIT[
“degree”,0.017453292519943295],AXIS[“Geodetic
longitude”,EAST],AXIS[“Geodetic
latitude”,NORTH],AUTHORITY[“EPSG”,“4326”]],PROJECTION[“Lambert_Conformal_Conic_2SP”],PARAMETER[“central_meridian”,18.20199966430664],PARAMETER[“latit
ude_of_origin”,54.13700866699219],PARAMETER[“standard_parallel_1”,30.0],PARAMETER[“false_easting”,0.0],PARAMETER[“false_northing”,0.0],PARAMETER[“standard_parallel_2”,60.0],UNIT[“m”,1.0],AXIS[“Easting”,EAST],AXIS[“Northing”,NOR
TH]]
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-08-001#65007-sha1:1fc9846)
Atlassian logo
