[Geoserver-devel] [JIRA] (GEOS-7128) Thread pooling causing WPS failures
Torben Barsballe created an issue
GeoServer / BugGEOS-7128
Issue Type:
BugBug
Assignee:
Unassigned
Components:
WPS
Created:
27/Jul/15 11:38 PM
Environment:
GeoServer WAR running on Tomcat 7 (Windows 7, Ubuntu 14)
Priority:
MediumMedium
Reporter:
Torben Barsballe
This issue does not effect core geoserver - it only seems to crop up when using certain downstream GeoServer extensions that mess with thread pooling.
Sometimes, when running a WPS request, I get an error response:
<ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ows="http
://www.opengis.net/ows/1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance
" version="1.1.0" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://loca
lhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd">
  <ows:Exception exceptionCode="NoApplicableCode">
    <ows:ExceptionText>Cannot switch process status from FAILED to QUEUED</ows:E
xceptionText>
  </ows:Exception>
</ows:ExceptionReport>
curl: (18) transfer closed with outstanding read data remaining
geoserver.log:
2015-07-24 11:00:35,817 ERROR [geoserver.ows] -
org.geoserver.wps.WPSException: Cannot switch process status from SUCCEEDED to QUEUED
	at org.geoserver.wps.MemoryProcessStatusStore.save(MemoryProcessStatusStore.java:53)
	at org.geoserver.wps.executor.ProcessStatusTracker.submitted(ProcessStatusTracker.java:59)
	at org.geoserver.wps.executor.ProcessListenerNotifier.fireProcessSubmitted(ProcessListenerNotifier.java:54)
	at org.geoserver.wps.executor.ProcessListenerNotifier.<init>(ProcessListenerNotifier.java:47)
	at org.geoserver.wps.executor.WPSExecutionManager$Executor.<init>(WPSExecutionManager.java:326)
	at org.geoserver.wps.executor.WPSExecutionManager$Executor.<init>(WPSExecutionManager.java:293)
	at org.geoserver.wps.executor.WPSExecutionManager.submit(WPSExecutionManager.java:177)
	at org.geoserver.wps.Execute.run(Execute.java:66)
	at org.geoserver.wps.DefaultWebProcessingService.execute(DefaultWebProcessingService.java:82)
	at sun.reflect.GeneratedMethodAccessor137.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
	at com.boundlessgeo.suite.geoserver.intruments.OWSServiceInstrument.invoke(OWSServiceInstrument.java:69)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
	at com.sun.proxy.$Proxy86.execute(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor136.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:841)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919)
	at com.boundlessgeo.geoserver.AppDispatcher.doDispatch(AppDispatcher.java:67)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:953)
	at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:855)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:829)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at com.boundlessgeo.geoserver.AppAuthFilter.doFilter(AppAuthFilter.java:111)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:957)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:620)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
If I run a number of request in succession, this error gradually becomes more common, until it is the only response I see (restarting geoserver fixes this temporarily).
When I stop GeoServer, I also see the following error:
SEVERE: The web application [/geoserver] created a ThreadLocal with key of type
[java.lang.InheritableThreadLocal] (value [java.lang.InheritableThreadLocal@anonymised.com
90]) and a value of type [org.geoserver.ows.Request] (value [WPS 1.0.0 Execute])
 but failed to remove it when the web application was stopped. Threads are going
 to be renewed over time to try and avoid a probable memory leak.
Jul 24, 2015 11:09:11 AM org.apache.catalina.loader.WebappClassLoader checkThrea
dLocalMapForLeaks
I have traced the issue through GeoServer, and have ascertained that WPSResourceManager is using a ThreadLocal to store the unique excecution id for the WPS process. Tomcat is reusing these threads, and when one of these threads gets reused by a different WPS process, the old excecution id is still stored in the ThreadLocal. Then, when the WPSExecutionManager tries to submit the new request, it grabs the ExcecutionStatus from the old request, tries to subit it as a new request, and gets the error “Cannot switch process status from FAILED [old request] to QUEUED [new request]”
Even though this does not seem to affect core GeoServer, WPS should really be doing proper cleanup of its ThreadLocal variables.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-08-001#65007-sha1:1fc9846)
Atlassian logo
This error does seem to be more the fault of the downstream extension mentioned, but should probably still be looked at.
Does anyone have any ideas as to why this issue hasn’t cropped up before? Is there anything in GeoServer that is cleaning up these ThreadLocals, or reseting pooled threads?
On Mon, Jul 27, 2015 at 2:39 PM, Torben Barsballe (JIRA) <jira@anonymised.com> wrote:
Issue Type:
BugBug
Assignee:
Unassigned
Components:
WPS
Created:
27/Jul/15 11:38 PM
Environment:
Priority:
MediumMedium
Reporter:
Torben Barsballe
&lt;ows:ExceptionReport xmlns:xs="http://[www.w3.org/2001/XMLSchema](http://www.w3.org/2001/XMLSchema)" xmlns:ows="http
://[www.opengis.net/ows/1.1](http://www.opengis.net/ows/1.1)" xmlns:xsi="[http://www.w3.org/2001/XMLSchema-instance](http://www.w3.org/2001/XMLSchema-instance)
" version="1.1.0" xsi:schemaLocation="http://[www.opengis.net/ows/1.1](http://www.opengis.net/ows/1.1) [http://loca](http://loca)
lhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd"&gt;
  &lt;ows:Exception exceptionCode="NoApplicableCode"&gt;
    &lt;ows:ExceptionText&gt;Cannot switch process status from FAILED to QUEUED&lt;/ows:E
xceptionText&gt;
  &lt;/ows:Exception&gt;
&lt;/ows:ExceptionReport&gt;
geoserver.log:
	at org.geoserver.wps.executor.ProcessListenerNotifier.&lt;init&gt;(ProcessListenerNotifier.java:47)
	at org.geoserver.wps.executor.WPSExecutionManager$Executor.&lt;init&gt;(WPSExecutionManager.java:326)
	at org.geoserver.wps.executor.WPSExecutionManager$Executor.&lt;init&gt;(WPSExecutionManager.java:293)
dLocalMapForLeaks
Add Comment
Add Comment
Atlassian logo
Geoserver-devel mailing list
On Mon, Jul 27, 2015 at 11:44 PM, Torben Barsballe <
Does anyone have any ideas as to why this issue hasn't cropped up before?
Hi Torben,
off the top of my head, I don't know, it may be that the process in
question is grabbing a WPSResource during execution?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
