[Geoserver-devel] [JIRA] (GEOS-7138) Problem parsing JSON for SQL layers
Federico Guizzardi created an issue
GeoServer / BugGEOS-7138
Issue Type:
BugBug
Affects Versions:
2.7.2, 2.6.4
Assignee:
Unassigned
Components:
REST
Created:
04/Aug/15 2:27 PM
Environment:
  • Linux Debian
  • Tomcat 7
Priority:
MediumMedium
Reporter:
Federico Guizzardi
I’m tring to override a sql layer on geoserver using rest interface (json).
My workflow is:
  1. get the original json from geoserver
  2. clone json using org.json java libs
  3. override original metadata entry with the follow
“metadata”: {
“entry”: {
@key”: “JDBC_VIRTUAL_TABLE”,
“virtualTable”: {
“sql”: “select * from mytablelayer”,
“name”: “mytablelayer”,
“escapeSql”: false,
“geometry”:
{ “srid”: 32633, “name”: “shape”, “type”: “Geometry” }
push it on geoserver using rest api.
What I get is this error on geoserver:
com.thoughtworks.xstream.converters.ConversionException: Expected element name but found sql instead : Expected element name but found sql instead
As defined on json.org:
An object is an unordered set of name/value pairs. An object begins with
{ (left brace) and ends with }
(right brace). Each name is followed by : (colon) and the name/value pairs are separated by , (comma).
so why geoserver checks about keys order?
I tested it on geoserver 2.6.4 and 2.7.2 with same result.
Thanks for support.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-08-001#65007-sha1:1fc9846)
Atlassian logo
