[Geoserver-devel] [JIRA] (GEOS-7140) WCS 1.1 GetCapabilities should advertise with workspace prefix
Bart van den Eijnden created an issue
GeoServer / BugGEOS-7140
Issue Type:
BugBug
Affects Versions:
2.7.2
Assignee:
Unassigned
Components:
WCS
Created:
04/Aug/15 9:07 PM
Priority:
MediumMedium
Reporter:
When doing a WCS 1.1 GetCapabilities request, GeoServer does not advertise the workspace, which can lead to conflicts. Also, when doing a GetCoverage, GeoServer will not accept the advertised identifier from the GetCapabilities response in case of duplicates (multiple coverages with the same name in different workspaces). When embedding a WCS request in WPS this leads to issues in my case.
WCS 1.0 and 2.0 do advertise the workspace in some kind of form.
2.0: <wcs:CoverageId>foo__dem_large</wcs:CoverageId>
1.0: <wcs:name>foo:dem_large</wcs:name>
1.1: <wcs:Identifier>dem_large</wcs:Identifier>
<?xml version=“1.0” encoding=“UTF-8”?><wps:ExecuteResponse xmlns:xs=“http://www.w3.org/2001/XMLSchema” xmlns:wps=“http://www.opengis.net/wps/1.0.0” xmlns:ows=“http://www.opengis.net/ows/1.1” xmlns:xlink=“http://www.w3.org/1999/xlink” xml:lang=“en” service=“WPS” serviceInstance=“http://localhost:8080/geoserver/ows?” version=“1.0.0”><wps:Process wps:processVersion=“1.0.0”><ows:Identifier>ras:Contour</ows:Identifier><ows:Title>Contour</ows:Title><ows:Abstract>Computes contour lines at specified intervals or levels for the values in a raster.</ows:Abstract></wps:Process><wps:Status creationTime=“2015-08-03T09:59:05.403Z”><wps:ProcessFailed><ows:ExceptionReport version=“1.1.0”><ows:Exception exceptionCode=“NoApplicableCode”><ows:ExceptionText>Failed to retrieve value for input data
No such coverage: dem_large</ows:ExceptionText></ows:Exception></ows:ExceptionReport></wps:ProcessFailed></wps:Status></wps:ExecuteResponse>
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-08-001#65007-sha1:1fc9846)
Atlassian logo
