[Geoserver-devel] [JIRA] (GEOS-7148) WCS 2.0.1 can send coverage in wrong format
Jukka Rahkonen created an issue
GeoServer / BugGEOS-7148
Issue Type:
BugBug
Affects Versions:
2.7.2
Assignee:
Unassigned
Created:
07/Aug/15 3:01 PM
Priority:
MediumMedium
Reporter:
Jukka Rahkonen
DescribeCoverage from the nurc__Img_Sample coverage which has an image “usa.jpeg” as source claim that the nativeFormat is image/jpeg
http://localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=describecoverage&coverageid=nurc__Img_Sample
However, GetCoverage that is given without format parameter is returning tiff image
localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=getcoverage&coverageid=nurc__Img_Sample
What returns should match the nativeFormat in DescribeCoverage. In this case the fix should IMHO be to change the nativeFormat into image/tiff because the definition of the native format in the standard is “encoding format where, in a GetCoverage request, the range set values can be obtained unaltered”. This could potentially be true with jpeg if you
request the whole coverage, or on boundaries of JPEG blocks, but not in the
general case.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-08-001#65007-sha1:1fc9846)
Atlassian logo
