[Geoserver-devel] [JIRA] (GEOS-7163) Integrated geoWebCache Cache setup
Tom Saul created an issue
GeoServer / ImprovementGEOS-7163
Issue Type:
ImprovementImprovement
Affects Versions:
2.8-M0
Assignee:
Unassigned
Components:
GWC
Created:
19/Aug/15 9:00 PM
Environment:
Any - tested on Java7, Tomcat8, Win64
Priority:
MediumMedium
Reporter:
Tom Saul
The (Caching Defaults) admin screen is currently split into two sections - the ‘Provided Services’ and the ‘Default Caching Options for GeoServer Layers’. The latter includes many non-layer specific cache settings - despite the name. These should be moved into their own section, and this one should only contain options that will be copied to layers as they are added. Specifically, things such as
Tile Locking mechanism
Cache type (File, Memory, …)
Cache type settings (based on above) - i.e. ‘Available caches’ for a Memory BlobStore
should not be in the layer section.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-01-193#70101-sha1:4fc7e3f)
Atlassian logo
