[Geoserver-devel] [JIRA] (GEOS-7165) Allow colons in coverage names
Clifford Harms created an issue
GeoServer / BugGEOS-7165
Issue Type:
BugBug
Affects Versions:
2.7.1.1
Assignee:
Unassigned
org_geoserver_catalog_impl_CatalogImpl.patch
Created:
19/Aug/15 9:36 PM
Priority:
MediumMedium
Reporter:
Clifford Harms
CatalogImpl allows layer names to contain colons. It assumes the string prior to the colon is a workspace, but falls back to assuming that the entire string is a layer name without workspace if the parsed name fails to return a result. CatalogImpl does not implement this behavior for coverage names - coverages with a colon in the name that are not also prefixed with a namespace name fail to return a coverage. This leads to unexpected behavior in some components (i.e. gs-wcs1_0) when it is assumed that a valid layer name is also a valid coverage name.
CatalogImpl should implement for coverage names the same type of fallback that it uses for resolving layer names.
I’ve attached a patch that implements this behavior, as names with colons in them are strangely a requirement of my organization, and have yet to experience any issues with t.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-01-193#70101-sha1:4fc7e3f)
Atlassian logo
