[Geoserver-devel] [JIRA] (GEOS-7168) A misconfiguration in md_metadata.properties throws generic error
Paul van Genuchten created an issue
GeoServer / BugGEOS-7168
Issue Type:
BugBug
Affects Versions:
2.7.1.1
Assignee:
Unassigned
Components:
CSW
Created:
24/Aug/15 5:18 PM
Priority:
MediumMedium
Reporter:
Paul van Genuchten
If you add this construct to md_metadata.properties (in /data/csw)
language.LanguageCode.@anonymised.com=‘http://www.loc.gov/standards/iso639-2/
language.LanguageCode.@anonymised.com=‘dut’
language.LanguageCode=‘Nederlands’
you will get a generic exception when requesting a getrecord
java.lang.ClassCastException: org.geoserver.csw.records.GenericRecordBuilder$TreeBranch cannot be cast to org.geoserver.csw.records.GenericRecordBuilder$ComplexTreeLeaf
could be improved by showing a message in the error which configuration item caused the error
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-02-247#70102-sha1:09808d3)
Atlassian logo
