Paul van Genuchten created an issue |
Issue Type: |
Affects Versions: |
2.7.1.1 |
Assignee: |
Unassigned |
Components: |
CSW |
Created: |
24/Aug/15 5:28 PM |
Priority: |
Reporter: |
when adding some metadata elements using the md_metadata.properties configuration, i noticed the order these elements were added to the csw-response was randomly (at least i couldn’t deduce what order was used, not the order from the properties file and not alphabetically) This breaks conformance with the schema, since the iso19139 schema defines a strict order of metadata elements The resulting metadata for me looked like: <gmd:MD_Metadata> If using the order of the properties file, at least users would be able to create correct metadata by using proper order in their properties file. Better alternative would be to check the schema for correct ordering. |
This message was sent by Atlassian JIRA (v7.0.0-OD-02-247#70102-sha1:09808d3) |
