Martin Lacayo created an issue |
Script extension installation causes GeoServer failure with BeanCreationException. |
Issue Type: |
Affects Versions: |
Community |
Assignee: |
Unassigned |
Components: |
Community modules |
Created: |
26/Aug/15 9:25 AM |
Environment: |
Debian 8 64-bit with Tomcat 8.0.14 |
Priority: |
Reporter: |
GeoServer fails to start after following the instructions for installing the script extension located at http://docs.geoserver.org/stable/en/user/community/scripting/installation.html. In the log there is “WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: java.lang.NullPointerException” followed by " ERROR [context.ContextLoader] - Context initialization failed This does not appear to be version specific. I can confirm that I have the problem with using http://ares.boundlessgeo.com/geoserver/2.7.x/community-2015-08-25/geoserver-2.7-SNAPSHOT-python-plugin.zip with |
This message was sent by Atlassian JIRA (v7.0.0-OD-02-247#70102-sha1:09808d3) |
