[Geoserver-devel] [JIRA] (GEOS-7179) ArcSDE Direct Connect not working
pvonminden created an issue
GeoServer / BugGEOS-7179
Issue Type:
BugBug
Affects Versions:
2.7.2, 2.7.1, 2.7.0
Assignee:
Unassigned
Components:
ArcSDE, Documentation, Oracle
Created:
31/Aug/15 6:59 AM
Environment:
  • Windows 7
  • 32-bit Oracle Client installed
  • GeoServer 2.7.2 + ArcSDE extension
  • ArcSDE version 10.2 over an Oracle 11g database
Labels:
ArcSDE
Priority:
HighHigh
Reporter:
pvonminden
After following the instructions detailed in the GeoServer documentation (http://docs.geoserver.org/2.7.1/user/data/database/arcsde.html), a direct connect does not seem possible. The same issue has been around with earlier versions as far back as 2.3.2. ESRI no longer supports three tier connections and insists on using direct connections from version 10.2 onwards (http://blogs.esri.com/esri/supportcenter/2015/02/11/where-is-the-install-for-arcsde-10-3/). To continue using GeoServer, a direct connection is vital if using an ArcSDE vs 10.3 environment.
An example of the error returned is as follows:
2015-08-31 14:58:33,365 WARN [data.store] - Error obtaining new data store
org.geotools.arcsde.ArcSdeException: Can’t create connection to none for Session #8[SDE error -66][Error desc=SPECIFIED PARAMETER VALUE IS INVALID.][Extended desc=
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-02-259#70102-sha1:6147844)
Atlassian logo
