[Geoserver-devel] [JIRA] (GEOS-7194) Offset when reprojection between EPSG:2154 and EPSG:27571
Adameve created an issue
GeoServer / BugGEOS-7194
Issue Type:
BugBug
Affects Versions:
2.6.2
Assignee:
Unassigned
Created:
08/Sep/15 4:02 PM
Priority:
MediumMedium
Reporter:
Adameve
After, I observed an offset between layers mixing 2 projections systems (EPSG:2154 and EPSG:27571), I did the following test :
I added 2 equivalent shapefiles of administrative divisions on Geoserver (Identical geometries but different CRS) :
  • Lorraine-EPSG2154.shp
  • Lorraine-EPSG27571.shp
and I did the following WMS request :
geoserver/ows?LAYERS=test%3Alorraine_EPSG2154%2Ctest%3Alorraine_EPSG27571&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image%2Fjpeg&SRS=EPSG%3A2154&BBOX=987436.33645055,6888999.1581421,1008233.8023471,6909796.6240387&WIDTH=900&HEIGHT=900
Then, I get an offset between the 2 layers (300m NS and 50m EW).
(See attached image)
It works fine with WFS requests.
Please let me know if you have any questions.
Thank you
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-04-018#70102-sha1:7e84d93)
Atlassian logo
