Peter Scarth created an issue |
Time series ImageMosaic store creation fails on versions > 2.7.1.1 |
Issue Type: |
Affects Versions: |
2.8-RC1, 2.8-beta, 2.7.2 |
Assignee: |
Unassigned |
Attachments: |
2.7.2.log, groundcover.zip |
Components: |
PostGIS |
Created: |
15/Sep/15 3:32 PM |
Environment: |
Debian 7.0 x64 vmlinuz-3.2.0-4-amd64 |
Labels: |
ImageMosaic |
Priority: |
Reporter: |
Creating a time series ImageMosaic that writes to a PostGIS table fails on geoserver versions > 2.7.1.1 with the attached logs and following error: WARN [gce.imagemosaic] - Unable to close indexingnull Note that the table appears valid in postgis, but the sample_image and layername.properties is not created in the data directory. Sample data is attached that will reproduce the problem after creating the appropriate postgres user / password: |
This message was sent by Atlassian JIRA (v7.0.0-OD-05-005#70102-sha1:a6815c2) |
