[Geoserver-devel] [JIRA] (GEOS-7205) Style Localization issues
Michael Colin created an issue
GeoServer / BugGEOS-7205
Issue Type:
BugBug
Affects Versions:
2.5.1
Assignee:
Unassigned
Localized_CountryCode_Parm.patch
Components:
WMS
Created:
18/Sep/15 8:31 AM
Labels:
SLD
Priority:
MediumMedium
Reporter:
Michael Colin
Hello,
Regarding Localized in Styles:
“lang” really only specifies the lang, not the country. If I try to use the locale instead, e.g. es_ES, it will simply not work.
A few other things that came up with my test cases:
Localized doesn’t seem to accept a namespace. In my example the following wouldn’t work whereas the 2nd snipped worked:
<?xml version=“1.0” encoding=“UTF-8”?><sld:StyledLayerDescriptor xmlns=“http://www.opengis.net/sld” xmlns:sld=“http://www.opengis.net/sld” …
<sld:Title>Design
<sld:Localized lang=“es”>Diseño</Localized>
<sld:Localized lang=“pt”>Design</Localized>
<sld:Localized lang=“ru”>Точность сетки</Localized>
</sld:Title>
working:
<sld:Title>Design
<Localized lang=“es”>Diseño</Localized>
<Localized lang=“pt”>Design</Localized>
<Localized lang=“ru”>Точность сетки</Localized>
</sld:Title>
When uploading a style through the GUI it is not encoded as UTF8 and the internationalised values are mangled. I had to upload them manually into the styles directory instead.
Thank you once again and have a good day
Michael
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-05-005#70102-sha1:a6815c2)
Atlassian logo
