[Geoserver-devel] [JIRA] (GEOS-7210) Character Encoding Issue With JDBC Config
Steve Ikeoka created an issue
GeoServer / BugGEOS-7210
Issue Type:
BugBug
Affects Versions:
2.8-RC1, 2.7.2
Assignee:
Unassigned
Components:
JDBCConfig
Created:
24/Sep/15 4:43 PM
Priority:
MediumMedium
Reporter:
Steve Ikeoka
The add(T) method in org.geoserver.jdbcconfig.internal.ConfigDatabase calls “new String(byte)” using the default character set. It should be called using “UTF-8” to be consistent with other code used by the jdbcconfig plugin that performs String / byte conversion:
  1. save(T) in org.geoserver.jdbcconfig.internal.ConfigDatabase
  2. mapRow(ResultSet, int) in org.geoserver.jdbcconfig.internal.InfoRowMapper
  3. save(Object, OutputStream) in org.geoserver.config.util.XStreamPersister
This can cause issues with encoding special characters if the default character set is not UTF-8 (e.g., the degree symbol appearing as °). The workaround for my environment was to add “-Dfile.encoding=UTF-8” when starting the application server.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-06-002#70102-sha1:82bb17d)
Atlassian logo
