[Geoserver-devel] [JIRA] (GEOS-7225) More than one geometry field in POSTGIS
Bogdan Vaduva created an issue
GeoServer / ImprovementGEOS-7225
Issue Type:
ImprovementImprovement
Assignee:
Unassigned
Components:
Created:
01/Oct/15 12:49 PM
Priority:
MediumMedium
Reporter:
Bogdan Vaduva
If I have 2 geometry columns in a postgis database, is there a possibility to select one of the two geometry to be used in a layer?
I can’t use views, because views are disabling primary keys on layers and therefor I can not use the layer for WFS updates.
What about the possibility to select a column as a primary key?
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-07-011#70107-sha1:db940e9)
Atlassian logo
