[Geoserver-devel] [JIRA] (GEOS-7226) Default GML links in Layer Preview page do not work for app-schema layers
Stefano Costa created an issue
GeoServer / BugGEOS-7226
Issue Type:
BugBug
Affects Versions:
2.8.0, 2.7.2
Assignee:
Stefano Costa
Components:
Application schema, Wicket UI
Created:
01/Oct/15 6:11 PM
Priority:
MediumMedium
Reporter:
Stefano Costa
The default GML link generated by the layer preview page uses WFS 1.0.0 as protocol and GML2 as output format, but this does not work for app-schema layers, since GML2 does not support complex features at all.
Clicking on the link results in a ServiceException response with the following error message:
java.lang.ClassCastException: org.geotools.feature.type.ComplexFeatureTypeImpl cannot be cast to org.opengis.feature.simple.SimpleFeatureType org.geotools.feature.type.ComplexFeatureTypeImpl cannot be cast to org.opengis.feature.simple.SimpleFeatureType
Ideally, the generated GML link for app-schema layers should:
  • use WFS 1.1.0 as protocol
  • use either GML 3.1.1 or GML 3.2 as output format, depending on the schema
  • use the global OWS service instead of virtual services, to avoid problems accessing secondary namespaces
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-07-011#70107-sha1:db940e9)
Atlassian logo
