I’m testing out the use of one ecw for an aerial instead of a directory
of geotiffs.
While with the geotiffs it was possible to ask for a tile which is
fully outside of the data extent, with an ecw (gdal extension) I get
the following error (both in 2.6 as in 2.8)
Error rendering coverage on the fast path java.lang.NullPointerException
Looking into the stacktrace, it is maybe something with generating a
colormap which has off course no data there?
Should I create an issue (I’m not able to attache a small ecw though)?
Or is there something I can configure to prevend this?
Below the full error and stacktrace
<?xml version=“1.0” encoding=“UTF-8” standalone=“no”?><!DOCTYPE
ServiceExceptionReport SYSTEM
“http://gng-ap713.nieuwegein.nl/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd”>
<ServiceExceptionReport version=“1.1.1” > <ServiceException>
</ServiceException></ServiceExceptionReport>
2015-10-05 13:51:32,878 DEBUG [org.geotools.coverageio.gdal.ecw] -
Creating a new ECWFormat.
2015-10-05 13:51:32,879 TRACE [org.geotools.factory] - ENTRY
(GridCoverageFactory)
2015-10-05 13:51:32,879 TRACE [org.geotools.factory] - RETURN
(GridCoverageFactory): found implementation GridCoverageFactory.
2015-10-05 13:51:32,880 DEBUG
[org.geotools.renderer.lite.gridcoverage2d] - Rendering using
interpolation javax.media.jai.InterpolationNearest@anonymised.com
interpolation javax.media.jai.InterpolationNearest@anonymised.com4306…
2015-10-05 13:51:32,881 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the
fast path
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:345)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:260)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:132)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:504)
at org.geoserver.wms.GetMap.run(GetMap.java:248)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at
org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at sun.reflect.GeneratedMethodAccessor272.invoke(Unknown Source)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at
org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at
at
org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at
at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy74.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor182.invoke(Unknown Source)
at
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:845)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at
at
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:503)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:421)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2462)
at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2451)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.geoserver.platform.ServiceException:
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1054)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:343)
… 118 more
Caused by: java.lang.NullPointerException
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:818)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:767)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:947)
… 119 more
