[Geoserver-devel] [JIRA] (GEOS-7232) bad or not json output via rest call to layergroup
Rot Ulet created an issue
GeoServer / BugGEOS-7232
Issue Type:
BugBug
Affects Versions:
2.7.2
Assignee:
Unassigned
autoroute.json, autoroute.xml, vecteur.xml
Components:
REST
Created:
06/Oct/15 5:03 PM
Environment:
postgis 9.4
  • Debian GNU/Linux 8
  • geoserver 2.7.2
  • jetty 9.2.11.v2015052
Priority:
HighHigh
Reporter:
Rot Ulet
  • 2 grouped layers (VECTEUR and AUTOROUTE) are created with many layers (not the same set of layer)
  • each layer has its own SLD style assigned
  • all layers can be previewed properly
The call to http://carto-geoserver:8080/geoserver/rest/workspaces/SDIS/layergroups/VECTEUR.json returns nothing and we get this exception in geoserver logs:
2015-10-06 14:47:27,539 ERROR [geoserver.rest] - Exception intercepted
java.util.EmptyStackException
	at org.codehaus.jettison.util.FastStack.peek(FastStack.java:39)
	at org.codehaus.jettison.mapped.MappedXMLStreamWriter.setNewValue(MappedXMLStreamWriter.java:121)
	at org.codehaus.jettison.mapped.MappedXMLStreamWriter.makeCurrentJSONObject(MappedXMLStreamWriter.java:113)
	at org.codehaus.jettison.mapped.MappedXMLStreamWriter.writeStartElement(MappedXMLStreamWriter.java:238)
	at com.thoughtworks.xstream.io.xml.StaxWriter.startNode(StaxWriter.java:191)
	at com.thoughtworks.xstream.io.json.JettisonStaxWriter.startNode(JettisonStaxWriter.java:103)
	at com.thoughtworks.xstream.io.ExtendedHierarchicalStreamWriterHelper.startNode(ExtendedHierarchicalStreamWriterHelper.java:17)
	at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.writeField(AbstractReflectionConverter.java:200)
	at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.<init>(AbstractReflectionConverter.java:189)
	at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doMarshal(AbstractReflectionConverter.java:135)
	at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.marshal(AbstractReflectionConverter.java:83)
	at com.thoughtworks.xstream.core.TreeMarshaller.convert(TreeMarshaller.java:70)
	at com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:58)
	at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.marshallField(AbstractReflectionConverter.java:250)
	at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.writeField(AbstractReflectionConverter.java:226)
	at org.geoserver.config.util.XStreamPersister$AbstractReflectionConverter.doMarshal(XStreamPersister.java:1470)
	at org.geoserver.config.util.XStreamPersister$LayerGroupInfoConverter.doMarshal(XStreamPersister.java:1953)
	at com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:43)
	at com.thoughtworks.xstream.core.TreeMarshaller.start(TreeMarshaller.java:82)
	at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.marshal(AbstractTreeMarshallingStrategy.java:37)
	at com.thoughtworks.xstream.XStream.marshal(XStream.java:1022)
	at com.thoughtworks.xstream.XStream.marshal(XStream.java:1011)
	at com.thoughtworks.xstream.XStream.toXML(XStream.java:984)
	at org.geoserver.config.util.XStreamPersister.save(XStreamPersister.java:555)
	at org.geoserver.catalog.rest.AbstractCatalogResource$2.write(AbstractCatalogResource.java:68)
	at org.geoserver.rest.format.StreamDataFormat$1.write(StreamDataFormat.java:49)
	at com.noelios.restlet.http.HttpServerCall.writeResponseBody(HttpServerCall.java:342)
	at com.noelios.restlet.http.HttpServerCall.sendResponse(HttpServerCall.java:306)
	at com.noelios.restlet.ext.servlet.ServletCall.sendResponse(ServletCall.java:306)
	at org.geoserver.rest.GeoServerServletConverter.commit(GeoServerServletConverter.java:54)
	at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:130)
	at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
	at org.eclipse.jetty.servlets.CrossOriginFilter.handle(CrossOriginFilter.java:256)
	at org.eclipse.jetty.servlets.CrossOriginFilter.doFilter(CrossOriginFilter.java:219)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
	at org.eclipse.jetty.server.Server.handle(Server.java:499)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
	at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
	at java.lang.Thread.run(Thread.java:745)
The call to http://carto-geoserver:8080/geoserver/rest/workspaces/SDIS/layergroups/VECTEUR.xml returns good data (see vecteur.xml file).
The call to http://carto-geoserver:8080/geoserver/rest/workspaces/SDIS/layergroups/AUTOROUTES.json returns strange data in styles tag (see AUTOROUTES.json file).
And here is the xml version (see AUTOROUTES.xml file).
Is this a known bug, as I not found something equivalent? Is there a workaround?
regards,
Rot Ulet.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-07-011#70107-sha1:db940e9)
Atlassian logo
