[Geoserver-devel] [JIRA] (GEOS-7241) Time dimension continuous interval is contrary to the standard
Martin Wegner created an issue
GeoServer / BugGEOS-7241
Issue Type:
BugBug
Affects Versions:
2.8.0
Assignee:
Unassigned
06-042_OpenGIS_Web_Map_Service_WMS_Implementation_Specification.pdf
Components:
WMS
Created:
12/Oct/15 6:03 PM
Priority:
HighHigh
Reporter:
Martin Wegner
The current GeoServer implementation of the time dimension continuous interval is contrary to the standard.
Current implementation is: ‘smallest domain value/biggest domain value/PT1S’.
The WMS specification says:
‘Data which are refreshed at regular intervals but not archived are represented using time/time/period, where
both time values are the same (that of the latest data) and the period indicates the refresh rate.’
For example:
With the current GeoServer implementation you cannot express a continuous interval of 10 minutes.
The right time dimension should be: ‘biggest domain value/biggest domain value/PT10M’.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-08-001#70107-sha1:2554118)
Atlassian logo
