Brad Hards created an issue |
Issue Type: |
Affects Versions: |
2.9-beta |
Assignee: |
Unassigned |
Created: |
25/Oct/15 12:46 AM |
Priority: |
Reporter: |
The H2 extension has two GeoServerApplication_ko.properties files - one in src/main/java and the other in src/main/resources. I assume that the one in the resource directory is being used. The two files are similar, but not identical:
I don’t know any Korean, so can’t say which is (more) correct. The fix will be to remove the one from java, and update the one in resource if necessary. |
This message was sent by Atlassian JIRA (v7.0.0-OD-08-002#70107-sha1:3f098e8) |
