[Geoserver-devel] [JIRA] (GEOS-7281) WPS - No Argument Process doesn't enter RUNNING state
David Blasby created an issue
GeoServer / BugGEOS-7281
WPS - No Argument Process doesn’t enter RUNNING state
Issue Type:
BugBug
Assignee:
Unassigned
Components:
WPS
Created:
27/Oct/15 11:37 PM
Priority:
MediumMedium
Reporter:
David Blasby
Currently, WPS Processes Enter RUNNING state when they fire a progress notifier (the notifier checks if its in QUEUED state and moves it to RUNNING). This notifier is fired after arguments are processed.
However, when there are no arguments, the notifier isn’t fired and the process does not enter RUNNING state.
This should be changed so it enters running state during execution.
This was found by a test failure in the geoserver scripting module (python - PyProcessIntTest.java).
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-08-002#70107-sha1:3f098e8)
Atlassian logo
