Darshan Lingegowda created an issue |
SLD renders lines in which are discontinuous (missing segments) |
Issue Type: |
Affects Versions: |
2.8.0 |
Assignee: |
Unassigned |
Attachments: |
osm_roads.sld, osm_roads.txt, tile caching.txt |
Components: |
PostGIS, WMS |
Created: |
29/Oct/15 12:06 PM |
Environment: |
geoserver 2.8 java 1.7 postgreSql 9.4 |
Labels: |
SLD geoserver |
Priority: |
Reporter: |
I am new to geoserver I have downloded osm.xml data and convert it to sql using osm2pgsql and then imported that postgis data to geoserver .When I try to render the roads using xml coded sld it gives discontinuous lines with missing lines segments and tile caching shows an error. |
This message was sent by Atlassian JIRA (v7.0.0-OD-08-002#70107-sha1:3f098e8) |
