[Geoserver-devel] [JIRA] (GEOS-7285) Help with call to custom WPS process
César Augusto Ribeiro created an issue
GeoServer / BugGEOS-7285
Issue Type:
BugBug
Affects Versions:
2.7.2
Assignee:
Unassigned
Components:
WPS
Created:
29/Oct/15 12:14 PM
Environment:
Linux
Priority:
LowLow
Reporter:
Following the Implementing a WPS Process manual, I’ve created a custom process that implements GeoServerProcess to call my own geocoding stuff.
After reading Accepting or returning raw data of the same manual, my goal was to have, at least, the possibility to choose the output type as json or xml in a dropdown (something like attachment expected.png) of WPS request builder (or REST call), but what I have is as attachment unexpected.png.
Is it possible to achieve what I want?
Here’s my code:
GeocoderCodLogr.java
@DescribeProcess(title = "geocoderCodLogr", description = "Geocoder em cima do Eixo de Logradouros, por código")
public class GeocoderCodLogr implements GeoServerProcess {
	@DescribeResult(name = "result", description = "Ponto como String", meta = { "mimeType=application/json,text/xml",
			"chosenMimeType=outputMimeType" })
	public RawData execute(@DescribeParameter(name = "código", description = "Código do logradouro") String codigo,
			@DescribeParameter(name = "número", description = "Número predial") Integer numero,
			@DescribeParameter(name = "outputMimeType", min = 0) final String outputMimeType) {
		String url = "jdbc:postgresql://lpostdes:5432/gispmpa?user=gispmpa";
		Connection conn = null;
		try {
			conn = DriverManager.getConnection(url);
			PreparedStatement stmt = conn.prepareStatement("select st_astext(geocode_codlogr(?, ?))");
			stmt.setInt(1, numero);
			stmt.setString(2, codigo);
			ResultSet rs = stmt.executeQuery();
			String ponto = null;
			while (rs.next()) {
				ponto = rs.getString(1);
			return new StringRawData(ponto, outputMimeType);
		} catch (Exception e) {
			// TODO Auto-generated catch block
			return new StringRawData(e.getMessage(), outputMimeType);
PS: I’ve ommited some connection string info.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-08-002#70107-sha1:3f098e8)
Atlassian logo
