My set-up consists of several ImageMosaic stores with PostGIS data
store. Two dimensions are defined - a “time” and a “forecast”. All
stores are updated every hour with many new geotiffs.
After about two days of runtime Geoserver starts to show wrong pictures
- instead of expected “forecast” value, it uses value taken about 15-20
steps (hours) earlier. Moreover, all next requests are shifted the
same amount of hours (offset) back.
I found that something happens after the ImageMosaic queries PostGIS about
a file name. In the following example, the query itself looks correct, but
file name reported in log is obviously wrong - “0100” (forecast “100”) instead of “1900”.
I believe that PostGIS table is correct. The same query asked manually
returns proper name.
The only workaround I know is to clear resource cache in Geoserver - from
that on everything works perfectly (since next failure after one or two
days).
That looks like Geoserver starts to use some old (cached) responses or
old connections to the database?
2015-09-03 07:13:24,891 DEBUG [geotools.jdbc] - SELECT
“fid”,encode(ST_AsEWKB(“the_geom”),‘base64’) as
“the_geom”,“location”,“time”,“forecast” FROM
“public”.“UM1_HIGH_CLOUD_AMOUNT” WHERE (“the_geom” && ST_GeomFromWKB(?,
100101
) AND “time” <= ? AND “time” IS NOT NULL AND “time” >= ? AND “forecast”
= ? AND “forecast” IS NOT NULL )
2015-09-03 07:13:24,891 DEBUG [geotools.jdbc] - 1 = POLYGON
((-1.7600189734073737 -3.7571876107040336, -1.7600189734073737
0.1875907849611185, 2.287338214041183 0.1875907849611185,
2.287338214041183 -3.7571876107040336, -1.7600
189734073737 -3.7571876107040336))
2015-09-03 07:13:24,891 DEBUG [geotools.jdbc] - 2 = 2015-09-03 00:00:00.999
2015-09-03 07:13:24,891 DEBUG [geotools.jdbc] - 3 = 2015-09-03 00:00:00.0
2015-09-03 07:13:24,891 DEBUG [geotools.jdbc] - 4 = 1900
2015-09-03 07:13:24,892 DEBUG [gce.imagemosaic] - Trying to resolve path:
type:RELATIVE
parentLocation:file:some_directory
***should be: “some_field_2015090300+1900.tiff”
