[Geoserver-devel] [JIRA] (GEOS-7294) Ability to make a Layer Group non queryable
César Díaz created an issue
GeoServer / New FeatureGEOS-7294
Issue Type:
New FeatureNew Feature
Affects Versions:
2.7.2
Assignee:
Unassigned
Created:
04/Nov/15 11:34 AM
Environment:
Windows 2008
Geoserver MSI Installer with Jetty
Priority:
MediumMedium
Reporter:
César Díaz
We have been digging into the possibility of making layer groups non queryable. We found out that this is not currently supported neither using the web console nor editting the XML files direclty. The latter thrown an error with the message below:
2015-11-03 19:56:46,149 WARN [org.geoserver] - Failed to load layer group ‘mapaBase.xml’
com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$UnknownFieldException: No such field org.geoserver.catalog.impl.LayerGroupInfoImpl.queryable
---- Debugging information ----
field : queryable
class : org.geoserver.catalog.impl.LayerGroupInfoImpl
required-type : org.geoserver.catalog.impl.LayerGroupInfoImpl
converter-type : org.geoserver.config.util.XStreamPersister$LayerGroupInfoConverter
line number : 231
version : null
Is setting layer groups as non queryable going to be considered in further releases of Geoserver?
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-08-005#70107-sha1:5fb2f7e)
Atlassian logo
