[Geoserver-devel] [JIRA] (GEOS-7296) Features fecthed from data source twice for WFS v1.1/2.0 queries
Alvaro created an issue
GeoServer / BugGEOS-7296
Issue Type:
BugBug
Assignee:
Unassigned
Components:
WFS
Created:
05/Nov/15 1:12 AM
Environment:
Running GeoServer (master) in Eclipse IDE. Tests using shapefiles as data provider or any WFS request available in the demos panel.
Priority:
MediumMedium
Reporter:
Alvaro
The WFS requests of 1.1/2.0 versions force to read the features twice from the data source.
The GetFeature operation in these versions needs precalculate the size of results (See: https://github.com/geoserver/geoserver/blob/master/src/wfs/src/main/java/org/geoserver/wfs/GetFeature.java#L318). It forces to read the features from the data provider (shapefiles) later (See: https://github.com/geoserver/geoserver/blob/master/src/wfs/src/main/java/org/geoserver/wfs/GetFeature.java#L531).
Finally when the results are encoded the features are fetched again (See: https://github.com/geotools/geotools/blob/master/modules/extension/xsd/xsd-gml2/src/main/java/org/geotools/gml2/simple/FeatureCollectionEncoderDelegate.java#L101).
There is a performance duplication issue. This issue is especially problematic with big data sources or complex/heavy querys.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-08-005#70107-sha1:5fb2f7e)
Atlassian logo
