Kevin Smith created an issue |
Removing a parameter filter from a set with other filter types may cause error |
Issue Type: |
Affects Versions: |
2.8.0, 2.7.3 |
Assignee: |
Components: |
GWC, UI |
Created: |
05/Nov/15 2:19 AM |
Priority: |
Reporter: |
If a parameter filter is removed via the web UI, and any filters following it in the filter editor table were of a different filter type, an error will result due to the wicket ListView being set to re-use its ListItem components. A list item containing an editor UI for one filter type will be used with another. |
This message was sent by Atlassian JIRA (v7.0.0-OD-08-005#70107-sha1:5fb2f7e) |
