[Geoserver-devel] [JIRA] (GEOS-7304) Geotiif Image not displayed in large Zoom Levels
Stephanos Charalambous created an issue
GeoServer / BugGEOS-7304
Issue Type:
BugBug
Affects Versions:
2.7.1
Assignee:
Unassigned
5-2800-3700ETRS89.tif
Components:
WMS
Created:
10/Nov/15 11:58 AM
Environment:
Windows and/or Linux
Priority:
MediumMedium
Reporter:
Issues regarding the WMS service of a Compressed Geotiff Image in ETRS89.
  1. Why in Layer preview the image does not look as clear when I use the WMS version 1.3.0. in compare with the WMS 1.1.1?
  2. Why there is no tile generation for the image after the scale 1:4261. Could it be because the image is in ETRS89 and the gridsets available are in WGS84 and Google Mercator? The resolution of the image is in degrees but it corresponds to 1mx1m that it is pretty high and should not normally cause any problem in much higher zoom level.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-08-005#70107-sha1:5fb2f7e)
Atlassian logo
