Andrea Aime [Administrator] created an issue |
A HTTPErrorCodeException gets ignored when wrapped inside a ServiceException |
Issue Type: |
Assignee: |
Unassigned |
Components: |
Main |
Created: |
18/Nov/15 6:05 PM |
Priority: |
Reporter: |
Code should be able to throw a HTTPErrorCodeException pretty much anywhere and have that code honored, however, if the exception gets wrapped in a ServiceException on its way up, then the error code won’t be applied. There is a simple bug in the Dispatcher logic that needs fixing |
This message was sent by Atlassian JIRA (v7.0.0-OD-08-005#70107-sha1:5fb2f7e) |
