[Geoserver-devel] [JIRA] (GEOS-7321) CSS Extension escapes HTML special characters in labels
Gregg Roemhildt created an issue
GeoServer / BugGEOS-7321
Issue Type:
BugBug
Affects Versions:
2.8.0
Assignee:
Unassigned
Components:
CSS
Created:
19/Nov/15 6:45 PM
Environment:
Windows 7 x64
Geoserver installed as a windows service
css extension installed
Labels:
geoserver sld
Priority:
MediumMedium
Reporter:
Gregg Roemhildt
Original Estimate:
1 day
Remaining Estimate:
1 day
Special characters like double arrows (code: «) get escaped in the sld to « resulting in the web map showing the incorrect result. If I go into the sld and modify it to the correct character code, it works as expected.
Use cases for this include labeling arrows on lines, or using a special font library like FontAwesome to place special icons on the map.
I am unable to attach images but I have tested this with both special html characters and font awesome codes like  and have had success in modifying the sld directly after saving the css file.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-08-005#70107-sha1:5fb2f7e)
Atlassian logo
