[Geoserver-devel] [JIRA] (GEOS-7327) Access to REST endpoints blocked when using LDAP authentication
Kevin Smith created an issue
GeoServer / BugGEOS-7327
Issue Type:
BugBug
Affects Versions:
2.8.1
Assignee:
Unassigned
Components:
Security
Created:
02/Dec/15 1:02 AM
Priority:
MediumMedium
Reporter:
Kevin Smith
Setup LDAP authentication with the test service per http://docs.geoserver.org/latest/en/user/security/tutorials/ldap/index.html (note the docs are out of date and miss a step where you move the new provider from “Available” to “Selected” after creating it.
Log in as the admin account from LDAP “bill” with password “hello”.
The Web UI shows as expected for an adminstrator. Attempting to use anything under geoserver/rest/ or geoserver/gwc/rest (the latter includes the web UI for setting up seed jobs) will give authentication errors.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-02-025#71001-sha1:64a64e8)
Atlassian logo
