Kevin Smith created an issue |
Issue Type: |
Affects Versions: |
2.7.4, 2.8.1 |
Assignee: |
Unassigned |
Components: |
Main |
Created: |
03/Dec/15 1:46 AM |
Priority: |
Reporter: |
The Layer Group Visibility Policy can only be set by changing the Spring application context file in the gs-main jar. At a minimum the property/variable mechanism should be used. Web UI + REST would be better. |
This message was sent by Atlassian JIRA (v7.1.0-OD-02-025#71001-sha1:64a64e8) |
