Jassi created an issue |
error in wfs query GetFeature using outputFormat=application/json |
Issue Type: |
Affects Versions: |
2.8.1, 2.8.0, 2.6.5 |
Assignee: |
Unassigned |
Components: |
WFS, WMS |
Created: |
04/Dec/15 5:27 PM |
Environment: |
GeoServer 2.6.5, 2.8.0, 2.8.1 |
Priority: |
Reporter: |
Hi, request=GetFeature & outputFormat=application/json & WFS I get the result and then I read result in GeoJSON() format with readFeatures() I am getting point features but with [X,Y] coordinate value as [NaN, NaN]. Same way getting extent for source is [NaN, NaN, NaN, NaN]. Rest other attributes returned correctly except X, Y and extent But when I switch Back to GeoServer 2.3 version, I get X, Y and Extent proper values. I have enabled JSONP in GeroServer web.xml I found this difference in results. GeoServer 2.6.5 result : “crs”:{“type”:“name”,“properties”:{“name”:“urn:ogc:def:crs:EPSG::27700”}} same error for 2.8.0, 2.8.1 version also. BR |
This message was sent by Atlassian JIRA (v7.1.0-OD-02-025#71001-sha1:64a64e8) |
